flatlander
plays dirty when losing
I realized the other day when I pinched the wastegate line to the sidewinder closed and only hit 11 psi that something must be wrong. So, while FINALLY getting my a/c woorking, I took the time to pull the intake hat off, scrape out the RTV that I used to "seal" it to the intake manifold, and put on an O ring from Banks to seal it right.
I also unbolted the wastegate actuator to play with it. When I unhooked the rod from the wastegate, the gate actually closed all the way. No wonder I hadn't been able to hit 10 psi, the gate was always partially open.
Anyway, tonight on the way to my folks I canned it and hit 13 psi to the motor and the boost from the psd turbo got to 5.5 or so. EGT's never got above 500.
Crusing at 60 nets 5 psi 450 EGT
65 7 psi 450
70 9 psi 500 deg.
I think I have room to play.
More later.
Barney
65 7 psi 450
70 9 psi 500 deg.
More later.
Barney
