Whin I get to 50% wmo and 50% deisel. My problem is constant smoke.
Anyone have ideas to reduce smoke. Added 10% unleaded to curent
mix will see how this does. Is there diferent injectors that would help
reduce smoke they all say they do but do they .Or any way to turn down fuel with amy programers on 03 dodges.I do filter to 2 microns before puting in tank.Allso the wmo has trans fluid in it to. The truck runs great just smokes.With deisel at 4.50 $ I can spend some to make changes to truck to make it work better. Allso does more lift pump presure reduce smoke curently run 5.5 to 7.5psi on original pump thinking of replacing pump. Any imput is needed. I can get rid of tailgaters very easy whin I step on it it puts out a Big Long Black cloud!
03 dodge cummins all stock except added fuel pressure gauge 133000 miles
