oregon101
I am having some issues on my 89 7.3 and need some advice. I have been running WMO for about a year and a half. I run roughly 90% WMO to 10% diesel. I started out with the factory mechanical pump but it went out in about 3 months. I then installed a Purolator Holley red knock off pump. Six months latter the fuel filter light started coming on and it was starving for fuel. I then installed an actual Holley red pump. The fuel filters are all good. It just went out also. I prefilter the oil to 5 microns before filling the tank. I then run a universal oil filter before the fuel pump, a Racor Vormax with a 3 micron filter and then the stock filter. The old pumps would still pull diesel but would not pull WMO when they got wore out. I am thinking about running two fuel pumps. An Airtex E8153 back at the fuel tank and then a Holley red under the hood. I have rebuilt the current Holley pump with a new rotor vane assembly and check valve. It works again but I don't want to keep having this problem. I know other people are running the Holley, Airtex E8153, Carter P4070, GP4389, P4594, Faucet 40109 and the Carrier pumps. What are people having the best luck with WMO?
