any known steering querks for '89 F-350
Bart F-350
FRANCE
Hello, are there any known steering perks for a 1989 F-350?
I had mine already popping it's steering reservoirs lid, and now when driving there's a slight vibration (transmitted by the steering pump I think).
My question includes the tie rod bar (or what is it's english name?)
One quirk with all these 4x4 frontends are the axle u-joints. Even though you are not in 4x4 and the hubs are not locked(nothing is turning) the outer axle u-joints can still freeze up from rust and cause the steering to act funny.
Balljoints can also rust and cause problems.
Rdnck84_03
Kansas
Usually when it blows the reservoir cap off then the pump isn't working. I know that if the belt on the power steering breaks and you drive it home, the cap will be popped up when you open the hood.
James
Kdo58
Puyallup washington
Have you changed out your track bar bushings? Mine was so bad, it made a thumping sound. When I changed it my steering wheel was centered when going down the road.
u2slow
bilge rat
Coastal BC
2wd or 4wd?
If the pump if sucking air, or lost prime, the foam build-up can push the cap off.
Is the vibration related to road speed?
Steering links (drag link and tie rods) need to be free of play, and greased regularly. Worn ones affect your wheel alignment and cause uneven tire wear and perhaps odd handling; usually not a vibration.
Bart F-350
FRANCE
you mean those at the wheels? the ones with thread? (I'm sorry, In English I don't know all the parts names.)
Bart F-350
FRANCE
2wd or 4wd?
4WD
Odd? never heard from that?
No, RPM, so it might be the pump?
As I said, I wasn't aware of any play in those, I only noticed that some of the rubber caps were weathered due to the sun. After all it's an extremely low mileage truck.
Then at the inspection they have this hydraulic torture machine for truck steering, and that revealed to the inspector that my steering bars had more play than he was happy with.
so he made a notice that I need to reappear within 2 months to show to him that I have repaired this situation.
tke395
