wiring question
dsbyrd
Virginia
I found a set just like you were talking about it a 8 pin 18-16 gauge wire will that work?
dsbyrd
Virginia
another question does the black Anderson connector plug into the red or how does that work
laserjock
Almost there...
16-18 should be okay I think. Both halves of mine are red. The one I bought wasn't the type that the two individual pieces (plastic bits ) clip together. It's a generic one. I'm moving the controller to the fender so one pole for each bank of gp's
Cruiseomatic
Defining Insanity
Dark side of the Sun.
You could loose your mind and do this.
But seriously, if you break the GP feed wires out, standard weather pack connectors will handle everything else. Anderson style connector on the GP feed and you are golden.
How in the hell did you get everything so clean and organized?!
I'm having hell trying to clean up my stock engine bay harness. And my goal is exactly what you have there. And honestly, I haven't even got close....
laserjock
Almost there...
Check out my build thread. It's easier when you start from scratch. LOL
laserjock
Almost there...
It wasn't too long ago. I can't really tell you where it is. Page numbers are different on Tapatalk. Probably June or July.
Post 1114. Sorry there's not a ton of info. I'll answer any questions I can.
Jimmylb01
Andrews, TX
Laserjock not trying to hijack the thread, but your coolant filter setup is nice, have any information on the block your plumbed through? It's nice and clean.
laserjock
Almost there...
It's not my thread. :D
That is a custom piece I designed and made to give me both a port and mount for the coolant filter and also coolant for my Garrett turbo. If you just want the coolant filter part, this one is bigger than you need.
I don't have a drawing of it per se.
laserjock
Almost there...
It's 1" thick by 4" wide 6061 bar stock. Passages are drilled to 1/2". Holes are tapped 3/8 NPT.
