Just redid valve cover gaskets because after last time I did them, they started leaking even worse than they had been leaking, and it seems that the leaks were all originating from around the bolt holes.
This time, I checked that the surface was flush along the valve covers and discovered that some of the areas near the bolt holes was not flush as if I had over-tightened them. Anyways, I straightened all the uneven areas out and even took a dremel tool to smooth out a few jagged edges near the bolt holes. When installing the gasket, I used RTV on the valve cover side of the gasket (I hadn't done this previous and wanted to see if it would help).
I reversed the load spreaders, tightened all the bolts down hand-tight, and then torqued the bolts about a half turn more starting on from the center and working to the bolts on the outside.
After going out for a test drive, the problem is exactly the same. There is oil coming out from the bolt holes. I'm not sure why this keeps happening. It's getting frustrating.
