Where's my 4x4 and cruise control lights?
EMD_DRIVER
Say what?!?!
Beaufort, SC
My 93's cruise control works pretty good, but I've never seen the "Speed Cont" light like my 99 Explorer has. Did the 93's have them?
Also, When I put the Tase shifter into 4wd, I get no 4x4 light. Where's it at?
A couple of months ago, I bought new and replaced all the bulbs in the instrument cluster. Still no CC or 4x4 lights.
tknomaj
Anaheim Ca.
Instrument lights
Just went to ALLDATA and checked there are no lights for 4x4 or for cruise was curious because I have not noticed them on my truck guess they thought it was a truck and not a toy so i was not required :dunno
6 Nebraska IDIs
Yes it has the 4x4 light. It is in the little square idiot light box to the right of the gauge cluster housing. It takes little LEDs I believe. Yours is probably burnt out.
tknomaj
Anaheim Ca.
No listing of lights on wiring diagram of instrument cluster or in wait to start lights or water in fuel light block have original ford diagram at work will check tomorrow but have looked in alldata 1993-1994 ford f350 4x4 and none found
160k87F250
not rocket science
York, PA
I know it has them, because when I did my bodylift, it caused the 4x4 light to come on.
John
6 Nebraska IDIs
^^^ Really, hmm. Ive been wondering this.... That would make one believe that the 4x4 indicator light would work off the principal of the light having a constant power source, and the switch being a ground connection switch allowing the light to turn on. Good to know. I've been wondering this.
tknomaj
Anaheim Ca.
Instrument lights
Well you tell me this is wiring diagrams and none to be found
zpd307
Zumbrota, MN
not the same, but..... my 90 has the 4x4 light but no cruise light. and both do work.
160k87F250
not rocket science
York, PA
Look on page 60-2 (instrument cluster)of the 93 Ford F series electrical and vacuum troubleshooting manual. 4x4 indiactor light circuit 210, low range indicator circuit 784. Looks like your missing a page.
John
Tknomaj: oopps, my fault. It's on the second attachment.
It's right there in plain view.
Dsl_Dog_Treat
Decatur,MI
Hey Gary, if the bulb is good for the t-case mode, make sure to check the connector on the t-case itself. Might be corroded or got knocked off.
Don't ask me how I figured that out.:rolleyes:
Furious George
Turner, OR
My 4x4 light only works if I put it into 4wd and then push the transfer case lever down slightly. Doesn't bother me enough to try and fix it.
tknomaj
Anaheim Ca.
Instrument lights
My Bad must be getting old or something looked at them twice:dunno
Any way hats off to mel :hail
Here are the circuits for transfercase and cruise
