If it's not one thing, it's another... *sigh*
After replacing my battery cables, replacing the pyro, and getting the glow plug system together (still working on the finishing touches, but still), I took my truck for a drive this evening. This is the first time I've driven the truck since late January, but my truck's sat for considerably longer than this in the past without any problems.
Well, after driving around for maybe 5 miles, I got home...and noticed a weird smell. I thought it was electrical at first, so I sniffed all around the cab and under the hood and didn't smell anything unusual. I then went to the back of the truck and realized that the smell was coming from the rear brakes. I then realized that it had seemed like the truck had a bit less power than usual, even though I know that I had released the parking brake (I even double-checked the brake lever to make sure it was released)...and came to the conclusion that the parking brake didn't fully release and that the brakes were dragging. On closer inspection, I saw smoke coming from the right rear drum...the left rear drum seemed okay, though. I then rolled the truck forward, and it actually rolled freely for about one wheel revolution and then bogged down.
I talked with my dad about this, and he said that it's consistent with a broken spring inside the right rear drum...does that make sense? If not, what should I be looking at in the E-brake system? Again, as best as I can tell, only the right side failed to release...although I haven't jacked the truck up to check this, based on the lack of smoke, heat, and smell on the left side, I think the left side's okay (although I certainly need to do hardware for both).
In any event, it looks like I have a brake job ahead of me...and this is the first time I've ever done a drum brake set, so I'm more than a little bit nervous. What should I expect, particularly with things overheating due to the brake shoe sticking? I haven't had a chance to look through my manual yet to see what all it entails, but I know that I have to pull the axleshaft (therefore needing to drain the differential) on the Dana 70 before even thinking about getting the drum off.
Any thoughts would be appreciated...and I know that D_C is going to be at me, but hopefully he won't be rude about it.
Thank you!
Thank you!
