What is this?
6 Nebraska IDIs
This might be shorted out, causing my alternator to run voltage full time.
sle2115
NRA LIFE MEMBER
Southeast Ohio
If you can make out the part number, I often go to fordparts.com and enter the Ford part number and it will give you a description. Works most of the time, but if the number has been superceded, sometimes it doesn't work.
6 Nebraska IDIs
Its the thing that mounts on the radiator support above the pass. headlight.
Might be 83 only.
And if anyone wants to know what one looks like on the inside, I've got one thats appart apparently too. lol
Cornelius (PDX), Oregon
:dunno
:confused: After-glow relay, 83; mounted in front of RH battery on fender :confused:
Google is your friend. Appearantly so is "dieselmann" I don't know him, but he has an IDI diesel store, and listed the part on his site. Maybe buy it from him since he helped you figure out what it is?:dunno
His page.
Makes sense, although I still don't think my 83' has one, which it must. :dunno Anyway, I've been helping Shawn out over the phone and he posted this pic at my request. He's got a problem where as his voltage regulator is full fielding the alternator even when the truck is off, and we're trying to chase down the cause. Shawn, you'll need the glow plug schematic I have here.
GaPchNCrm
Franklin Ga
This is the exact same problem Lockedhearts was having, you may want to PM her to see what the shop she used did to fix it.
h2odrx
Anti-O
Coastal Neckville, NC
Mine did that too, it was the blasted rebuilt alt....
new Alt and volt reg good as new....
boy now that my brother works at the auto parts store 20% discount is soooo coool!!!!!!
6 Nebraska IDIs
Trust me,
If it were the alt or the reg. it would be fixed many times over.
I've changed the alt atleast 4 times and literally done in 37 regulators.
Something is causing it to do this.
6 Nebraska IDIs
Huh????
:dunno
His page.
zigg
Victoria,Canada
Just in case you aren't familiar with this. The after glow relay was separate in the early models. It was to help with cold start up and to reduce white cold start smoke. On the later models, it was incorporated into the glow plug controller at the back of the drivers' head, and then later with the 7.3printed circuit controller, is also built into the unit.
Normal starting is glow plugs lit for 10 secs or so, then start the truck, and the after glow relay will trigger on/off cycling of the glow plugs for about 90 seconds to help warm up.
The connection to the alternator was so that the relay/controller saw voltage to tell it that the truck had started and needed the cycling...
Zigg :)
