Diesel JD
Hey guys, I have a line on a DNE2 overdrive unit for a Ford diesel with a C6 4X4, I want to use it with a T19 2WD, does anyone know what needs to be done to make it work? Thanks a bunch,
JD
JD
I'm about 80% certain that U.S. Gear Dual Ranges go between the tranny and the transfer case. I would imagine the DNE2 does as well, but I can't say with any certainty.Unless I'm mistaken, the DNE2 is virtually the same as the US Gear Dual Range. I'm almost sure that it goes after the t-case.
