What else am I missing
psy9zach
keego harbor michigan
So this all came with the truck to make it turbo am I missing anything
Sent from my ASUS_A006 using Tapatalk
psy9zach
Happen to have a picture soon know what I'm looking for, I'm trying to figure out what all the steps are for setting up a turbo. Like where do you pull oil from?
I don't but I know that Thewespaul does. That's another thing I don't see, the oil feed line. From the factory, the oil came from the bottom hex piece that thee oil pressure sending unit screws into. The sender itself is mounted on top of the turbo. It's ok if you don't have this piece. There's PLENTY of aftermarket options to get oil to your turbo.
The_Josh_Bear
Western WA
Also don't see the base to the air filter housing. Maybe its directly under the top but it doesn't look like it.
3Kp
Indiana
It's all there. The oil feed line is in the plastic back (installation kit bag I bought off of type 4)
maybe missing the V band. Believe you can get them from tractor supply
