DragRag
I have 40 in the rear, 50 in front a per chalk test. Maybe I am spoiled but compared to my coworkers '95 F250 turbo diesel [with almost the same tires, pressure and all,] his has the proverbal 'Cadillac' ride. Other than the turbo and a year newer the ride should, [in my mind,] be close to the same. Or is there differences I don't know about?
There really isn't much differenc between the trucks, unless you have a higher GVW spring, it is possible. Only othe thing that could make a difference is shocks. I wanted a softer ride on an excursion I had so i switched to the Rancho shocks that had the adjuster knob on it so I could fine tune it with how much shock resistance I out in. Those RS9000's made a good difference.
