CrewCabFanatic
Decided today was the day to do a full fuel system service...front to back. Ive got new tanks, lift pump, return line kit, injectors, injector pump, fuel filter, and glow plugs just because I'm already in there.
Everything has been smooth sailing so far except for one issue. I can't get the bottom two nuts that connect the injection pump to the gear housing off! It seems I need some sort of magical contortionist wrench to get in there
It's the last thing I have left to do on the fuel system, and I've got a core due and I don't want to put my vendor behind on my core return. Everything else went great, but those two dang bolts! Anything you could recommend that might be found at the local hardware store, or should I just buy a grinder and see if I can't make a 9/16 box end fit in there?
Thanks in advance, if anyone knows it'll be you guys!
