What am I even doing sometimes
BrianX128
Pittsburgh
I've been trying to get a good bit of work done this winter on the 7.3 while I drive the 6.9, and I've had some comical screw ups along the way I just have to mention..
I put my 3G alternator in, worked great but the belts always screeched. I took a suggestion from someone on here to use my old pulley instead of the dual groove one that came with the new 3g alternator (even though it said it was for an IDI) and it helped but didn't fix it. Then I got to thinking I can't tighten this belt anymore.. but I use the short vbelt that only goes around the water pump so maybe that is why I have a screech. Sure enough my ps/ac belts weren't tight enough to drive the water pump pulley hard enough when the 3g needed a full draw.
I did the clutch pedal assembly swap, but didn't put the steering column back in correctly. Then I stood beside the truck trying to figure out how my steering wheel was 180* off (upside down) when the truck was pointed straight. I took the 13mm bolt out of the shaft under the hood, and realized that I couldn't put the shaft back on the steering column side 180* the other way to make it right. Turns out, my intermediate shaft came off when I pulled the column and since it has the flat side to make it only go one way on the column side, I had to rotate it. Then the steering wheel was finally right.
Then I didn't hook the speedo cable back up. After leaving it out of the trans and puking fluid all over my garage floor.
My inspection plate started clacking after my smf conversion, that was scary.
Then I went to change the zf5 shifter bushings, and apparently the metal part of my "stick" that goes in the top of my trans was worn on my old shifter that was already assembled, it still felt so loose even with the new plastic pieces. My trans was from a 90, but I put in a 95 zf5 from a powerstroke that was fully rebuilt but 2wd and a guy near me was getting rid of it. He gave me the top part of the shifter but not the stick so I had just re-used mine. I took the stick and bolted it to the middle portion with the plastic pieces, put new bushings on it and now its super tight.
After all of this, all is well that ends well. I drove the truck to work tonight and everything is working perfectly.
My only complaint after all of this, is my new clutch pedal assembly is 95% travel, my old one was like at best 60% cause of how worn it was, but my "missing" % in the new assembly I got from a parts truck isn't the bushings, it's the little stupid pin on the swing arm, it's not worn away though on the eyelet for the pushrod, the pin is pressed in and not welded to the swing arm and it moves the tiniest amount ever in the swing arm.
I thought about trying to zap the back of it with the old wire welder in the cab, but I'll likely catch the truck on fire lol.. it's so much better than what I was dealing with, I just really am picking at hairs with that tiny movement I held a tape measure by the pedal and it loses me 1/4" of travel on the clutch at the foot part of the pedal its nothing.
I didn't realize these things were ever pressed in and not welded. I wish I would have saw this while it was out on the bench, but the pin is so tight to the pushrod I didn't want to delay driving the truck any longer to do the heim joint mod either with all new parts I just greased it well. The pedal is super easy to push. I might still try to tack that pin, I just hate welding in confined spots like that.
Aren't old trucks fun? lol..:peelout
chillman88
Central NY
Yep a few of those fixes you did are on my list for this summer. Mainly rebuilding the pedal box.
I've had the column out so many times I could probably change it with my eyes closed though...
BrianX128
Pittsburgh
If you are doing your pedal box and ever wanted your dash lights to be brighter while you have the cluster out sitting on the tailgate, its a great time to put in some little 194 led wedge lights. I have always seen people use blue or white led's, and so to be different I tried red led's in mine.
I'll post a picture here in a bit, I'm on night shift at work this week and couldn't tell on my way in if I was going to like it or not.. it looked different, that's for sure.
chillman88
Central NY
I thought about it but frankly I don't like my lights turned all the way up anyway. I'd love LEDs but they'd have to be fully dimmable. Truthfully I'm thinking about replacing the high beam indicator bulb with a lower output bulb because it's too bright for my taste lol.
BrianX128
Pittsburgh
So the red is actually pretty awesome the way the needles and warning areas of the gauges stand out but the greenish backing of the other areas doesnt let much light through so they are dimmer. It's pretty cool.
The_Josh_Bear
Western WA
Those needles seriously stand out! Nice mod and red wont hurt your night vision nearly much as other colors. Does it dim?
subway
be nice to the admin :D
York PA
hey it is all part of the learning curve sometimes working on anything. it is what separates a specialist from a general mechanic. they learn all the ins and outs of those little things that make the difference!
This^^^
How many techs are left in the world that are trained on these trucks? It’s a lot of trial an error and learning on the job. That’s why it took me over 4 years to get mine back together. Nobody is good at everything. Being good enough to get by at a lot of things is not a bad life skill to have.
catbird7
PA
This^^^
There may be a sizable population of "trained techs" remaining however most are likely getting monthly SS checks verse a weekly paycheck. Meaning you're unlikely to encounter one at the local repair shop because most of these guys & gals are retired. Lets face it, the newest IDI out there is what, 25 years old? The best mechanic available is likely the guy holding the steering wheel and why this website is so valuable to those owners like myself who rely on the knowledge available here.
FarmerFrank
Blairsville, Pa
I have been wanting to do the blue LED’a in my truck but damn, I think I’m going to try the red instead!!
How many are back there? Been a while since I’ve had mine out
tke395
