What am I doing wrong
psy9zach
keego harbor michigan
Got the prob in the hole and this is what I'm getting
Sent from my ASUS_A006 using Tapatalk
Offset is a just a setting, not your actual degree of timing. Iirc, you want 20* of offset with it in the gp hole.
You aren’t getting a good signal off the crank. It shows the offset if it’s not getting a good crank signal. Been there.
psy9zach
Auto correct on the phone and the fact the words come out faster in my head then my fingers can move is a challenge some times, I had a hard time getting the magnet sensor down in the hole and back out I used a drill bit the same size by hand to clear it out but it didn't go well bc I had to use channel locks just to get it out I was saying in the picture I noticed he didn't have the spring that sits in that grove that I would assume is for holding it still do we have to take it out to get the sensor into the hole like does it make it to wide
Yes I had trouble with mine. I ended up taking the drill to mine. I did also remove the spring clip.
