Just recently I started having this problem when I start my truck, the engine will run between half and WOT throttle for about a second before returning to a normal idle speed. This problem has occurred twice when I'm starting the engine cold, and once when warm.
It seems like this problem only occurs if I depress and release the accelerator before starting the engine. Since I live in a warm area, I never start the engine while depressing the accelerator pedal, however, I will depress and release it before attempting to start the engine, so that the fast idle/cold advance is activated once the engine starts. Other than this issue, the the truck runs just fine, it also starts quickly, even when temperatures got in the 30's around here.
