Waterpump Flowrate
JeffMoss1
Jeff
Colonie, NY
Does anyone know how much flow our water pumps output?
Like gallons per minute.
Does anyone have a educated guess?
thanks,
Jeff
The flow rate is 70 gallons per minute @ 3000 rpm. Kinda an amazing amount of flow. The pulley drive ratio is 1.08:1. This is if you are running the factory thermostat. Anything else wont work at all so don't try it. The thermostat will start opening at 192 degrees plus 0 degrees or minus 7 degrees and is fully open at 212 degrees. Mounting bolts torque is 14 lbs.
JeffMoss1
Jeff
Colonie, NY
geez thanks man. How'd you know all that?
So that'd fill up a 5 gallon bucket in about 4.8 seconds.
awesome, that's what I needed.
Jeff
placidoert
