Goofyexponent
Mentally Unstable..
It's time for me to install my "A" pillar gauge pod. I have an older Pyro from an L9000, a mechanical water temperature and a mechanical Oil pressure gauge.
There is no problem with the oil pressure gauge and where I have the line tapped in, it works flawlessly now. All I need to do is legnthen the 1/2 air fitting by about 6" with the compression fitting I already have to make the gauge reach the Pod.
The mechanical water temperature gauge, however, needs to have the probe moved to make the gauge reach in the pod. I have a 1990 IDI out of a truck and I noticed a plug between cylinders 5 and 7 (on the driverside, back two cylinders) on the head near the exhaust ports. It is a plug, but does it lead into the water jacket, or into the oil ports?
There is another port behind cylinder 8 (last cylinder on the passenger side head) with a plug in it. Is the the water jacket or the oil galley?
Right now I have my probe in the top of the water pump, which from what I understand, reads the water temperature coming from the radiator.
