Drew2010
As the title says, ive got water in the oil. I have only about 700-1000 miles on this oil change. Today I was out taking the intake box off to look for my mysterious oil leak, when I got to looking down the filler tube and noticed some milky looking goo. So upon further inspection I pulled off the cover on the front of the timing cover and found the same milky residue. So since my valvecovers have a slight leak i figured I would pull the drivers side (easier) and inspect that..... Wouldnt ya know its full of that crap.
What could be the cause of this? I did alot of hot water pressure washing on the motor after my 4 quart leak that "fixed itself" could the water get in the motor some how? Also thought could the Oil Cooler be leaking internally? My antifreeze levels arent low but Im not saying it couldnt be. Any Ideas guys? Im getting tired of all this and am thinking of pulling the motor to reseal it.... Im just getting frustrated and want to drive this thing. My 96 has 1200lbs of ballast for plowing so its sucking the gas..... Thanks in advance for any help...
Oh and since I know you guys love pictures....... You can click on em to make them bigger
