Wait to start light comes on
mf7lakes
North Carolina
Driving down the road - Wait to Start lite comes on -- sometimes bright, sometimes dim, sometimes flickers
1) what sets it to come on ?
2) what to do to check that glow plugs aren't heating ??
Voltmeter is steady with no show of spikes or overly high voltage.
Thanks in advance
Big Bart
Tow&Slow
Newport Beach, CA
Purple wire off the glow plug controller with the special connector on it powers the light. I would unhook the wire when this happens to see if the light goes out and stays out. If unplugging it stops the light from coming on focus on the connections to the glow plug controller and the controller itself.
Check the wiring to and from glow plug controller. If the wiring to it goes on and off (Wiring issue, bad ground, bad ignition switch, etc.) it will keep resetting the controller and it will go on for another 5-10 seconds. If the light goes on but does not turn the relay on and sends power to the glow plugs I would replace the glow plug controller.
To see if it is powering the glow plugs put a test light or volt meter on the big terminal of the glow plug controller with the bent metal part on it. If that side is powered then the glow plugs will be on. I would not unplug a glow plug to test as if the system senses 2-3 bad glow plugs it will shut down. So if you have a couple bad glow plugs and unplug a third it will shut off and your test will not show a true result.
Watch this video.
mf7lakes
North Carolina
Finally got to this -- 6 bad glow plugs -- (could not start when temperatures dropped) but controller showed signs of overheating with burn marks on 2 of the wires -- eventually wait to start light came on bright and steady while driving. Replaced all plugs + controller -- system back to normal.
Big Bart
Tow&Slow
Newport Beach, CA
Glad to hear it!
Can you send a pic of the fried GP controller. Just hit attach file located at the bottom of the editing/reply box. Or copy on your pc and paste in the editing/reply box.
m2rtin
