If this pic works, you'll see how US gear accommodated the different transmission side options. The 2wd install required taking off the tailshaft housing and replacing it with the OD housing, which is basically a extra long 4wd housing.
So there must have also been a tranny output shaft adapter sleeve to go from the slip yoke splines to the T-case splines on the front of the OD box. (unless they're the same spline configuration, which they aren't on my old trucks).
At the back of the OD box, is there another "adapter sleeve"? Or were there separate output shaft options?
I'm just trying to figure out what parts I'd need to scrounge up to make this thing work. Info is pretty scarce on these already...
It would be really helpful if someone with the us gear 2wd could post up
