So far I got the oil cooler cleaned up, put new o-rings on it, painted(ford blue), and put back on, the thermostat and water pump installed. I figured that since I had everything off of the engine that I might as well put new valve cover gaskets on. I ended up having to put on all new steel brake lines( winters ), hoses and new wheel cylinders. Here are a few pictures for now if the dial up modem would go any faster I could post more pictures at a time.
