I read your entire post three times and appreciate good solid information from someone with plenty of first-hand experience.
Is your confidence in Power Service mean using it for it's anti-gel properties, or it's lubricant properties only ?? (just want to be sure of what you are meaning)
Please explain your use of isopropyl in detail.
Where and how to buy, what ratio/gallon, when and why you use it, etc.
Thanks.
I have to apologize for a post that had a spelling error of one letter that proved to be critical.
by "rec" cans of isopropyl, I meant
RED as K_Williams1982 pointed out. And it is INCREDIBLE in extreme cases of frozen fuel lines both gasoline and diesel fuel. My first experience with that was back in 1986 when I was driving my truck to school.
The truck died because it was so damn cold out, and I didn't want to leave it until that evening and pull it home with the tractor. So I dropped in a couple cans of
RED HEET and 20minutes later the line was thawed and my truck made it the rest of the way there. I wasn't even late since I was a computer geek and was going to work on the computer before school started so I was 45 minutes early anyway. But I digress...
We had always run the
RED HEET in our tractors and vehicles until my brother started school for Diesel Mechanics in fall of '89, that's when we started using Power Service as he discovered it in school. And we used it winter/summer religiously in our diesel systems since. It does have great lubrication qualities as well as anti-gel properties. However when there is a chance that some moisture got in the system or the weather dips VERY low, we still all the
RED HEET as an extra precaution. It may be overkill, but I'd rather not be stranded. And in twenty some years of driving in sub-zero weather as well as nearly forty years of working diesel tractors and equipment out in weather colder than the steel and hydraulics care for, I have yet to have any more freeze ups since that one day in high school.
Bear in mind when I say
RED HEET, I am referring to a couple of different brands of Isopropyl in the red container. I even use the stuff in the summer time in my gas engines as an injector cleaner, one can ever or every other tank. Depends how much running I do but usually one cal per ten gallons as noted on the container.
