Diesel JD
Hey guys, I'm just wondering if you all think this is par for the course or if I should be doing better. Its on an '86 F250 longbed extended cab, C6 2WD 3.55 gears, 90% city 10% highway. I think my timing may be retarded...the truck is almost as quiet as a gasser sometimes after a long pull, I know I have some fuel return leaks, and an injection shop guy said it wash psuhing some fuel out of teh advance piston or weep hole, however I don't know how he could tell where the fuel was coming from given the amount of return line seepage
Where is the weep hole and how is the best way to check for a leak there? Well just wanted to put it out there and see what you all think. Is this normal or not quite good enough? Also this is on B100 biodiesel, no or light load most of the time, good fuel additive almost always. Thanks,
J.D.
J.D.
