Turning up the fuel
I was woundering if anyone could help me?
I was going to turn up my pump. ATS says take out 1/4 in screws and open access , remove rubber gasket and turn engine until you 5/32 allen screw is centered in the opening and turn 1/4 turn.
Sounds easy enough, I took off the access plate, removed the gasket and turned the engine and I dont see a hole lot happening.
What is going to happen?
It looks like there is a hole on the back side of the access hole,Is that going to move forward? or in that hole is there the screw?
I dont know if I need to keep turning or I am doing something wrong.
Thanks
John
