Trying to figure out what axle I have.
Fordfan90
Idaho
I have a 1990 f250 4x4 extended cab long bed 7.3 idi. I'm going to be doing my front wheel bearing but can't figure out what axle I have under it. Any ideas? I checked the door tag but don't see anything for the front axle.
MtnHaul
California
I have a '92 F250 4x4 extended cab that had a Dana 50 up front so I would "guess" you likely have the same if it isn't a solid axle. Of course I can't say enough good things about swapping to a solid front axle like the Dana 60.
Fordfan90
Idaho
Is it hard swapping over to a Dana 60?
MtnHaul
California
Not really. But if you go that route GET THE DRIVER'S SIDE U-BOLT BRACKET!! The bracket is Dana 60 specific and will make the swap simpler. Just make sure you get a Dana 60 made before Ford went to the 170mm bolt pattern, and there was a change in the brake mounting somewhere around 95-96, not sure about that though.
Macrobb
North Idaho
It's doable... but why?
The dana 50 TTBs are plenty solid and will run just fine.
The only thing you have to do is replace the bushings once in a while(like every 20 years or something).
The only /downside/ to the TTB is you can't just shove lift blocks under the leaf springs and lift the truck.
You have to make sure that the relationship of the centerpoint to the edges is the same, or your tires won't drive straight.
As long as you aren't screwing it up with half-baked lift kits, you'll have no trouble with it.
Also, Dana 60s are expensive.
MtnHaul
California
I guess I just preferred the ride of the D60 to the D50, and yes they are expensive.
Fordfan90
Idaho
I heard that the ttb was a junk front end and they come out of alignment all of the time?
DaveBen
Ukiah, Ca
I had a TTB axle in my '92 F350 and it never needed alignment by a shop. I checked the toe-in and the camber angle and that was it. Never had to change any of it until I rebuilt the king pins. I would never have a TTB again because of the no lift.
Trevtron
Katy, Texas
My 83 with TTB has been hassle free. And it hasn't been rebuilt or messed with except for a fluid exchanges and grease. Ford bragged about those in the earlier 80's as being the cats meow for traction and ride stability
FORDF250HDXLT
Maine & Oklahoma
hesutton
The Anti-Anderson
Bowling Green, KY
Never been of fan of the TTB. Dana 60 had been under my F250 for 11 years. Can't see any reason why I'd ever go back. In my opinion, it beats the TTB Dana 50 in all categories.
There is a reason Ford abandoned the TTB and still puts Dana 60's under their trucks in 2017.
Heath
why?
fewer moving parts to go bad.
and the best reason of all......
you don't need 40 acres to make a U-turn in a D60 like you do in a D50.
:D
F-series pickups did not change the wheel bolt pattern until 1999 when the new chassis was introduced.
here's what a changeover should look like.
Somewhere around 95-97 they swapped to a better bolt on caliper instead of slide pin only. Easier to keep greased. Lol
