Transmission question
austin92
Brazil. IN
Yup, I want one :)
1983 f350 6.9 zf5 2wd srw single cab long bed. Facet duralift, optima red tops, bfg all terrains, 4" exhaust from y pipe back, autometer z series pyro, pump turned up 2 flats
rustygold
conway Arkansas
Ebay had them nv4500 nv5600 zf5-6 and a few more transmission about 170 for two but I would like to find the black ones seams like the would transfer heat better, but the aluminum would hold about 1qt more fluid each so it's a toss up for me.
Sent from my SAMSUNG-SM-G870A using Tapatalk
austin92
Brazil. IN
I couldn't see color affecting heat dissipation unless it was in sunlight. Might do a trans temp gauge and those heat sinks when I get my axle and clutch done
rustygold
conway Arkansas
Not the color just it has more fins look at the one on its side.
austin92
Brazil. IN
Ah, I see now
rustygold
conway Arkansas
Ok I'll have to look at it then they don't want the tranny but all zf5 psd will fit a 7.3idi. Right? I haven't seen the truck yet so idk what's in it and year just heard from him
Pork_Chop50
He looks kinda hairy and slobbery to me....
Willamette Valley, Oregon
While I am no expert in this field, I have to play devil's advocate. There is a least one working example of a ZF6 placed behind an IDI by "Jaybee". It has inspired me to eventually ditch my E4OD for the 6 speed, as I would prefer a manual and I like the 6's ratios. The caveat being if you want to have 4x4 then you need to source both ZF6 and NV271/273 transfer case as the OBS BW1356 does not bolt up. Check out this thread ZF-6 behind an IDI and also Standard Transmissions What you need to know to decide if the 5 or 6 is what you want.
rustygold
conway Arkansas
Jasper right if it's not bolt on then I don't want the hassle of it would be nice but my job has me working 70 to 90 hours a week very little down time
Exactly.
That's why I said the zf6 won't more.
And it's not worth the hassle over the zf5. All the 6 really gets you is a granny low gear.
FORDF250HDXLT
Maine & Oklahoma
is this where i get to hijack your guys threads and say:
PUT AN E4OD IN IT! :D
dedicated to all you thread hijacking ZF5 freaks........you know who you are.:D
