Transmission Cross-members
dancrowley
danc01
south of Boston
Hi All, What is the best transmission cross-member to use when converting from a four speed trans. to a ZF 5 speed. Also what year Ford truck had the side gusset brackets that angled back. Thanks. Dan
Can you use the old crossmember? I thought the 4 speeds and the zf were very close to being the same. When I swapped my zf in where a c6 resided, I found the lower crossmember for the c6 was exactly the same as the zf lower crossmember from the donor. It just needed to be slid back 1 inch. The short upper crossmembers were different, the zf short uppers had more offset to compensate for the 1 inch slide back, and still used the same frame holes.
dancrowley
danc01
south of Boston
Yes I can, but my problem is, I need to find the the upper cross member gussets that angle back, but I don't have their part #s or know what year and model Ford trucks had them. Dan
lewisstevey7
