TRANSFER CASE ???
PARKESPOWER
I JUST PURCHASED A 1992 F-250 WITH A BAD TRANFER CASE BUT THE TAG ON THE CASE IS BROKEN OFF SO I HAVE NO IDEA WHAT CASE IT IS. CAN ANY ONE OF YOU GUYS HELP ME IDENTIFY WHAT CASE IT IS AND WHERE TO FIND A REASONABLE REPLACEMENT THANKS CHAD
NJKen
is a daddy!
Central NJ
Post the vin and all the codes off the door sticker. I might have the information to decode it. If you have a 351 or a 460 I am almost certain that you have a Borg Warner 1356. There are a couple of varities of these T-cases but most all pickups used the same one. It will have a slip yoke on the rear output shaft, a bolt on front driveshaft and may have PTO provisions and may have Electric shift.
Best of luck
Ken
PARKESPOWER
1FTHF26H8NLA03003 IS THE ID
IT IS NOT ELECTRIC SHIFT BUT THAT IS ALL I KNOW
NJKen
is a daddy!
Central NJ
I'll try to find my VIN decoding paperwork. In the meantime I am almost certain that you are going to have the 1356 T-case. You can try sending National Drivetrain an e-mail and see what they can do for you. They are a good comapny in my book.
I'll get back to this post when I find my books. Til then, best of luck
Ken
PARKESPOWER
THANKS I THINK I FOUND ONE THAT WILL WORK. SORRY FOR THE LACK OF RESPONSE I WAS AWAY FOR A WHILE
Grizzly Wrecker
