Well, after months of the car sitting here the owner showed up and just signed it over to me. I decided since I had the intake gasket to give it a try. I replaced the intake gasket, and the thermostat since I was already there, and it fired up, but was running rough. After replacing an O2 sensor, plugs, wires, and coil pack (popped check engine light and when retrieved said ignition spark error). It runs nice and smooth, but out of the blue it starts to idle rough for a bit (sometimes just dies as smoothly as shutting the key off) and then will smooth back out. Sometimes I have to rev the throttle a bit before it smooths out. What could be causing this? No codes for any sensors either, and the check engine light doesn't even come on. Could it be that the gas (been sitting in it since mid December) is bad already? I dumped some gas treatment in it and added $7 (all I had left to my name) of "plus" gasoline in it, and it seemed to help a bit, but not completely. What could I be overlooking? As long as it's out driving, it's fine. After it idles for a bit, it acts like it "loads up" and runs like crap for a bit. I double checked all the vacuum lines, sensor plugs, and connections but it's still acting weird. I'm at a loss now, and any advice would help.
