Freight_Train
Traitor to the brotherhood
Ummm,Ok I had one of those LOOONG boring nights at work.I gave it some thought(since I am paying good money to have a engine put in the Enterprise) on how to make smoke and lots of it but still have a turbo!I wondered if I could hook up a solinoid valve to the pressure side of the intake so if I had a tailgater that just wouldn't go away I could flip a switch releasing boost pressure inturn robbing the engine of needed O2 causing an overfueling issue with LOTS of smoke(and an eye glued to the Pyro!).Or those time when you just wanna show off and outsmoke your buddy in the PSD!
I originally tried to figure out a way to rig up a linear actuator of sorts to the waste gate and have a floating waste gate rod.Have it so I could move waste gate open via the actuator but it would make things too complecated and too slow to work like I wanted.Plus there was that chance I could totally screw up a good waste gate.I wanna be able to make so much black smoke on command it will look like Q has been playing with my truck for 007.
