Too much fuel filtration, microns and WMO
Jbone36
California
So my original water separator was leaking air, replaced with goldenrod water separator running after a seachoice electric pump. Im debating installing another filter of smaller micron either before fuel pump or after at the IP. Im planning on running wmo in the coming months. How much filtration is too much until it can mess things up from starvation or something?
NeverHave-I-Ether
Texas
Long as you have fuel pressure maintained there isn't a problem with multiple fuel filters, though you want to be within reason. My set up has 3 filters and I run a Holley electric fuel pump. Just watch your fuel psi. If it's too low a filter is clogged your pump isn't strong enough. Rule of them is expect psi drop for a clogged filter.
Never-Ether
