Time to Flush!
Neal_P
Getting ready to flush out my coolant in my truck and going to use these instructions:
1.) drain thru petcock, fill with tap water.
2.) run engine until hot (run on road for a couple of miles), and drain thru petcock, and fill with tap water.
3.) Repeat step 2.) 4 times
4.) Repeat step 2.) with distilled water. Do this 4 times.
5.) Drain thru petcock, fill up with 4 gallons of coolant
When it gets time to fill up with distilled water how many gallons does it hold each time I fill it up? Want to know how many gallons of it to by. And I got underneath and just kind of eyeballed around for the petcock. Which side is it on? Thanks.
Mike
Stroker
Cora
Petcock on my 95 is on the drivers side of the radiator. I cant remember what year truck you are driving Neal, but it should hold n the neighborhood of 30 qts + or -. Here is a good site with a procedure on it.
Coolant flushing
lewisstevey7
