Tie-Rod End Bushing
Spun4Fun
NC
Does these bushing pressed or i have to buy the complete sway bar link for each side . i stopped out of curiosity at the ZONE and found that you can't just buy the bushing which i think its a BS ..
Can i press new busing ? Mine are sloppy , dry and causing my steering lock to lock to hit like a wrench in a can
Waystro
No Class
South Texas
So you just want the Rubber not the metal tab?
Looking at my 86 it appears there the same style that's on my Suburban.
these are energy suspension bushings.
Spun4Fun
NC
Nop i started the thread wrong ... it's my Tie Rod ends .. Both of them are shot , sloppy and have enough play in them . surprised that the darn shop who did my alignment did not see them or say any thing
They did see them...they wanted mo money.....when u ckme back for second alignment after replacing them.
Spun4Fun
NC
Yup ... I agree that was the shop i wont let them touch my break system or ball joint because they quoted me $1100. I said NO . I done them my self with buying new tool for close to $300 but took the truck back to them for alignment ..lol
Can i just replace both Tie rod ends ? I seen some replacement at rock auto
I honeztly cant recall if your TRE's are both replacable or not I think so...look
If so start soaking **** outta them and keep soaki g with pb or liquid wrench etc
Alignment or toe in iz easy to do.
Anyway look and you can answer yer own question
Administrator Moderator
P.S. - I fixed the title.......
Rock Auto = if there listed for your truck they'll fit. Count how many turns it takes to take the old ones off, screw the new ones on the same amount of turns, alignment will be awful close. Just don't turn the coupling, only the end.
Lazy ass Autozone guys can order them.
they got them.
http://www.oreillyauto.com/site/c/s...nd&year=1994&make=Ford&model=F-350&vi=1126875
EDIT Better go Rock Auto, didn't know they where a sponser til just now.
By Sniclas
http://www.oilburners.net/forums/for...p?153-RockAuto
RockAuto is a really good place. I just ordered my parts for the P71 from there last night... and the code knocked a bit off....
Waystro
No Class
South Texas
I just did the Tie Rod Ends on my suburban nothing else
i got it aligned pretty good but went ahead and had a Shop do it just so it was 100% hey tires are expensive $55 wasn't bad at all.
tke395
