Throttle position senor and high idle solenoid....?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
ok on my 6.9 it's going in the scout with a t-19 behind it, so i don't need any form of TPS right? it came with what looked like a vac regulator TPS prob for a C6 right? ALSO do i need the high idle sole. if i don't run it in the winter? if so is it self regulated or does it go to a sensor? how do i hook it up? i'm making a custom harness for the ENTIRE scout and i'm going to be getting to the engine part realllll soon. ;Sweet
Thanks!!
-Jon :peelout
sassyrel
iowa
high idle sol has a sensor by the thermostat housing-hot to one side of sensor--other wire to the sol. when warm enough, sensor cuts out, sol goes to idle. cold weather or not---hook it up, otherwise,let off throttle cold, may kill on ya.
LCAM-01XA
my very own hell
I agree, hook up the high idle solenoid, put it on a switch even - them 200-300 extra rpms do come nice when you gotta crawl, whether tis in traffic or down the trail, especially with a bolt-action trans. Proper way of installing a manual switch involves wiring in a diode there, and I highly recommend not skipping on it as without the diode I've had my engine do a semi-runaway thing several times. Detailed instructions here:
http://www.oilburners.net/articles/high idle override.htm
Dsl_Dog_Treat
Decatur,MI
As said, install the high idle,it's there for a reason.;Sweet
Even on cool days and a cold start,a couple of hundred rpms does help warm the motor up faster and helps reduce wet stacking conditions.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
i'll hook it up stock where can i get the sensor by the thermostat? oh and i'm guessing i don't need the TPS then eh?
thanks!
-Jon
LCAM-01XA
my very own hell
Don't you already have the sensor in place? Look by the #1 glowplug, tis between that and the thermostat housing elbow.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
no i tossed all the sensors..... cookoo is that on the driver side of the motor? above the waterneck? i'm going to be using a bulb style tenp gauge too, not sure if it'll interfere with here the sensor goes....
-Jon
LCAM-01XA
my very own hell
Tossed it, eh? Way to go bud! lol :D But yah, that's the driver side of the motor, on top of it, between the water neck and the #1 glowplug. New sensor you can get from a dealer, maybe also apart stores but not too sure on that.
LCAM-01XA
my very own hell
It's a temperature switch actually, triggers that small square relay that powers the high idle and cold advance solenoids.
suv7734
BC Canada
This is the sender. As mentioned it gets power and puts that power thought to the high idle solenoid below 112 deg. F. Try to locate your old one because the last time I priced one Mr. Ford was very 'proud' of it.
Cincinnati Guy
Cincinnati, Ohio
Try Green Sales Company here out of Cincinnati, they have them, thats where I got mine from there genuine Ford parts cheaper then dealer. They will even ship it.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
hmmm its next to the UPPER waterneck eh? i think i put a block off plug in there i'll have to look, while i'm at it anybody have an online engine wiring diagram? :confused:
-Jon
P.S. did i ever mention i HATE wiring! -cuss
6.9poweredscout
Bleeds IH red...
Northeastern Pa
i have one in my parts engine i'll grab and clean up. any luck on a diagram? :dunno
then i do not need any form of TPS correct?
-Jon
