Camarogenius
Tried searching for ZF5 PTO, and it wouldn't let me.
without knowing the tooth count for the transmission countershaft, the answer is no. the good part is you may be able to swap out the gears in the PTO to make it work.Are they "universal"? If I bought one for my ZF5, and later repowered the truck with a CTD and a G56 tranny, would the same PTO unit work?
This is a serious question, as I'm looking at putting the F-450 to work.
But you could probably make or buy an adapter to keep the ZF5 even if you swapped in a Cummins. I hear PTOs are expensive, so it might be worthwhile. What kind of work do you have in mind for that truck?
I've always felt the search here is better than it ever was on TDS though.
I've been able to find what I've searched for here.![]()
I tend to use the advanced search for google & use oilburners.net for the domain when I'm searching for something too short for this search engine or with multiple words.![]()
