The search function sucks.
Camarogenius
Gilmer, TX
Are they "universal"? If I bought one for my ZF5, and later repowered the truck with a CTD and a G56 tranny, would the same PTO unit work?
This is a serious question, as I'm looking at putting the F-450 to work.
without knowing the tooth count for the transmission countershaft, the answer is no. the good part is you may be able to swap out the gears in the PTO to make it work.
david85
Campbell River, B.C.
I agree the search function sucks. Exact phrase searches are hit and miss and multiple word searches often only catch a single word out of many in the search field.
Its true on all forums though since they all seem to use the same software.
Diesel JD
Gainesville, FL
But you could probably make or buy an adapter to keep the ZF5 even if you swapped in a Cummins. I hear PTOs are expensive, so it might be worthwhile. What kind of work do you have in mind for that truck?
I've always felt the search here is better than it ever was on TDS though.
Camarogenius
Gilmer, TX
Mainly residential work. Rock, sand, gravel and mulch for home owners that don't want to pay for 15 tons when they only need three. Also, the sides will be removable so it can work as a regular flatbed hauling cargo, and I'd like to be able to pull the bed and bolt on a 5th wheel when I want to pull my gooseneck, or my mini-float.
I think I've been to that site about three times since I found this one.
oregon-mike
Eugene, OR
I tend to use the advanced search for google & use oilburners.net for the domain when I'm searching for something too short for this search engine or with multiple words. ;Sweet
NJKen
is a daddy!
Central NJ
Thats the one I use too. Works for any forum better than the forum search.
Ken
crispy74
