no.running around town im not building much,if any boost while empty.i can hit 1100 degrees pretty quick on the highway empty at about 2PSI.with that loadi was running around 800 degrees and 10PSI boost.this truck is wierd.around town and on the highway unloaded its a gutless sled but put 1 or 2 cars on its back and hang on!!been like that since igot it.it seems to grow a huge sack when its loaded.
Does your turbo have a wastegate? If yes, maybe you need to adjust it, or it is stuck and turbo is only spools at higher load/rpm? That 1100 deg pyro temp makes me think IP fuel screw turned up too high in combo with the non-functioning wastegate. OkieGringo
I've seen pics of your rig before.
Still amazed at how well it carries 2 cars.
When I was still towing, our guys ran GM 3500HD's
and they always sagged like they had 12,000lbs on
the deck with a double load like that.
fuel screw and waste gate never tweaked,yet :Sly .well im happy with the EGTs and power while loadedbut not happy with the exhaust system at all.$800.00 for a poorly made exhaust is a huge
