89dieselbko
Sunday i drove down to altoona, caught a movie with the wife. Everything going smooth.
We drove to ******* barrel (yummy chicken and dumplins) Engine felt weird. Kind of down on power, no puffs of smoke when i down shifted which is odd when i raise the RPMs on the downshift. Motor also *seemed* to be vibrating more then usual, i take this as running rough. So i park and pop the hood. it all *sounds* fine but for sure its running rough and vibrating the BKO more then usual. I checked the motor mounts, they were new when i did the swap less than 4000 miles ago.
It never did smoke much, except on hills loaded. or when i down shift and the RMPs bump up i get some smoke. Of course if i get on it i get some too.
My return lines need changed, but i dont think it would cause this issue at all.
So here is where i am now. Planning on top end rebuild with a turbo as per my thread last week. Working out prices/specs still, *** should be returned/sent soon. But i dont know what my problem now is. Here is what i have done, it now has a no-start condition, not even a small shot of ether works. Tried gas on rag first. also didnt work. Full symptoms and what i have checked out so far....
1. Really bad vibration from the motor on the way home. Temp sat right at 205 as it always has. Oil pressure was good.
2. Got home and shut it down. Waited for it to cool down, and could NOT get it to fire no matter what i tried (even tried to drag it in gear with my trail blazer. just wouldnt fire)
3. I checked my fuel flow at shreader valve on fuel filter. While cranking it was shooting out pretty good. At this point i was thinking my IP crapped out. So i tested it the only way i know... Checked voltage at my FSS. it was 11.6. I thought this was low. But when hitting my FSS toggle switch you can hear it click. It does feel/sound like its rough running while cranking it. And im getting next to no white smoke puffs on start up (figured i should be as my GPs are disabled as i was using gas/ether to try to start it) Fuel filter i drained, filled with ATF, went a few cranking sessions and went to be. This morning still no start. Didnt try gas/ether again but glowed it like normal and just cant get anything out of it.
Does this sound like the pump? maybe cavi issue? My coolant is oil free, and my oil is coolant free *i believe* not milky/bubbly. The motor most likely needs head gaskets. among other things that im currently planning for.... but my issue is, could these issues be something in the bottom end of the motor? I have tried searching around, found bad vibrations from bad injectors, IPs going bad, bottem end going. cavi causing comp loss and a vib/knock. I dont think i would call my noise a *knock* but it was really rough, and now its dead.
Anyone have any thoughts? not sure where to go from here in regaurds to the rebuild budget, and what i may have to go without (turbo) if this turns out to be a pump, thats a pretty large portion of my wife limited budget on this. Thanks for any insite!
