fastass350
SStock8569
So, it's time not to tear down my 6.9, have the heads checked and refreshed, and some rings and bearings. I have a few questions...
Does anyone locally have a compression tester for these I might be able to borrow, maybe for a case of beer or some cash or???
The head studs I've read about, is that something mostly important on turbo'd models? Or is it something I should do, having no plans of installing a turbo.
If head studs are not so much a necessity, should the head bolts be replaced? I know I've used them a few times over, not knowing one way or another.
Is having the block pressure tested something that can be done, to verify there are no holes in the cylinder walls? If so, anyone local have any recommendations?
This motor has possibly over 500k, it's had rings and bearings and an oil pump at about 300, along with heads, which have been replaced once since then. It has run upside down for about 15-20 seconds
, once, which was about 25k ago. Otherwise it's well maintained.
Thanks for any input anyone may have.
Chris
![Sweet ;Sweet ;Sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
Chris
