Dsl_Dog_Treat
I have a 6.9L bellhousing I'd like to trade for a 460 one...For a T-19...
Might be able to help ya with that.
Seems to me this is not an uncommon issue at all. However, wasn't there also an aluminum bell housing used on some trucks? Would that be better/stronger? Also, if you don't mind, can you take a picture of your damaged area - if I ever get around to the 4-spd swap and find a non-cracked housing I'd like to know where to beef it up so it never gives me trouble. Google images has not been very useful for this.Mine is cracked where the fork goes. Its a couple inches long, but i've been driving like that forever. weld it up and you'll be good as new...
I see someone already welded up old cracks, just to get new ones develop right next to welds. It appears there is enough clearance around the opening to allow 1/8"-thick strips of flat stock to be welded on to reinforce the thin walls, so that's what I'd be attempting even if the housing I get ain't cracked.
Actually mine is aluminum...
The cracking is going out from the opening for the cluch fork. It's pretty thin there...
Necromancing this thread with a stupid question - I know mixing DMF and SMF parts is less than ideal, but can a DMF (Valeo to be exact) be used with 11" T19 clutch and pressure plate? If not possible, then where do ya'll T18/19 folks get your new flywheels from?
Edit: Justinray, do you have any pics of your shifters with the Ranger installed?
DO NOT FORGET.....351M/400 have same bell housing pattern as 460
Just saying, you open more doors with more knowledge!
Look to older say early 80's trucks with a 351M 4sp!
