T19 only grinds going into 4th gear
kickdheney
Port Angeles, Wa
Been ironing the links out in the truck. Clutch bites real good1-3 and it doesn't seem to be slipping even when hauling 10000 lbs. But it grinds going into 4th every time. Any ideas?
4th gear syncros are done. time for a trans rebuild or a ZF5 conversion.
MTKirk
Billings, MT
If you don't want to rebuild learn to float between 3rd and 4th. A lot of times if you keep your rpms up when shifting it will go right into 4th even if you haven't completely matched shaft rpms. I'd wait till I had another reason to pull the tranny/engine and rebuild or do a zf swap then.
chris142
SoCal
The synchronizer gets the gear up to speed so it will engage with another when shifting. When they wear out you get a grind.
2 things to get you by. Double clutch going into that gear or no clutch. Both will help once you get the hang of it.
Hydro-idi
Lodi, California
Double clutching is easy once you get the rhythm down. It should go right into gear without grinding if you do that. That’s what I do with all my old tractors that don’t shift worth a crap.
olsen726
