T19 oil and diff oil preferences...
McGIDI
South Carolina
I am going to do a full fluids change when i get home from here... I know what im doing for oil but not for tranny and diff... what weight should i run...
McGIDI
South Carolina
thanks man... does it matter which brand i dont think these trucks are as picky as far as gear oils...
if you have a posi rear, IRC 85-140 full synthetic!
80/90 reg in trans, however I'm partial to a 85/140 synthetic for trans too!
warhog
TN
It matters enough you get IP banned from sites for mentioning brand...
lolwut?
If a board has a problem with someone mentioning what brand they prefer and why, than it's probably not a site worth going to because all they're doing is pushing their advertisers on you wether it's good stuff or not.
chris142
SoCal
Some folks say that gl5 and gl6 has addatives that can damage the brass parts in the trans. Don't forget that gear oils and motor oils are rated on a different scale. a sae 50 motor oil is the same viscosity as a sae90 gear oil.
Kevin 007
Full-floater
Nelson BC Canada
I run 75W-140 in T-19's. And the same in the rear. But it also gets colder up here then it does down there....so.... you may not benifit from the extra spendy synthetic
