T-case shifter rattle
MtnHaul
California
Since I've owned my truck the t-case shifter starts to rattle/hum at about 2400-2500 RPMs and I have read the recall/TSB notice regarding this issue. From what I have read the "official" fix was a new shifter but that seems excessive. I found one fix here where a member suggested slightly prying on the mechanism from under the vehicle until a small pin no longer makes contact with the t-case housing. Sounds easy but I tend to be cautious when it comes to "use a bigger hammer" type fixes. What fixes have you guys had success with? The rattle gets annoying and I'm worried I'll blow my speakers if I turn 'em up any louder!! Thanks in advance.
Black dawg
sw mt
putting a grease fitting and pumping the shifter assy full of grease, makes a big difference in this. Also keeps it from getting stuck..they are well known for that.
FORDF250HDXLT
Maine & Oklahoma
Was that member me? If not,I did this also and it cured all that ailed her.It took me a few times looking to figure out just where that rattle was being made.Once I saw the issue,the fix took just a few seconds.Don't worry,a little prying isn't going to break it.
MtnHaul
California
Yep F250HDXLT, when I searched on this issue here your post was about the only useful thing I found. Great idea too Dieselcrawler--kinda' don't like having to push down to get into 4-Lo, especially since I actually use it as 2-Lo all the time. Hopefully this weekend I'll get it sorted out, thanks for the replies.
crispy74
