Swap questions
grnstang
Norwalk Ohio
Hi guys i have a 1995 dodge ram 2500. i am going to swap a 12 valve cummins in place of my v10. I have a NV4500 manual transmission. 12 valve is out of a 95 dodge manual tranny. I know I need motor mounts, input shaft, fuel tank, lines, wiring harnesses. I have that aspect covered. What else do I need to know? Will the flywheel bolt up? Clutch? Any help is needed thanks - Jeff
nevrenufhp
torque ******
Sacramento
I believe the nv4500 was the same for the Cummins and the v10
I looked all this up before. My buddy got a 4500 from a V10 for his 4BT swap project. Trans will bolt up, clutch is the same, you just have to get a different flywheel. The rest is pretty basic, the obvious stuff you already know about. You should get the PCM computer from the Cummins truck too, it will work all the gauges, cruise, and stuff.
JU57US
