ah1988ford
Ok in my previous thread I was posing about the parking breaks hanging up.
I pulled the brake drum off of my drivers side rear, it was really stuck on I had to turn the star adjuster forever to get the drum loose enough to get off.
I sprayed everything down with brake cleaner,I wiped the brakes and the inside of the drum with a rag I put the drum on, then adjusted the brakes so they just barley scrape the drum but the drum still turned. I put the tires back on and pump pump and pump the brakes I floor it backwards and hit the brakes to try to get them to adjust. The passenger side wheels would skid, the drivers side would not (the drivers side it the side I pulled the drum on ) so I thought I needed to tighten up the drivers side some so I tightend them with the star on the rear of the drum. I pull foward and they firmer but they do not skid like the passengers side still, so I tighten the drivers side some more about 3/4 of a turn, they start to lock up again like they did before ! So I thought if I loosen them 3/4 of a turn it would bring me back to where I was before but they still lock up.
My neighbor asked me what I was doing and I told him what I just typed and he said I need to change the fluid (been sitting for 2yrs) and I need to pull both the rear drums and adjust both of them so the brakes scrape them a little then drop the truck, pump the brakes a few times floor it backwards and
slam on the brakes And to not touch the star wheel after that !
Is this right? Could someone please help I am about to shoot myself lol !
