Stumped and looking for some help
RustyLove
Cape Cod, Massachusetts
Hi guys I'm new here and looking for some help. I have a 1994 F350 7.3l idi N/A and the wiring has seemed to go on the fritz. Everything had been working fine until a few days ago when these issues started happening. When I start the truck the tachometer will jump to a random rpm before not reading at all, the directional switch will cause the tachometer to jump at the rhythm of the blinker before going to zero, the blower fan speed switch is acting like a dimmer switch for the gauge cluster, and the aftermarket radio that worked before won't even turn on. I've checked all fuses both in the cab and under the hood and nothing is blown. I'm pulling my hair out and need some guidance. Thanks
austin92
Brazil. IN
Something that bad, I’d make a “triangle” of grounds. Body-frame, frame-engine, engine-body. Worked for me on my old jeep Comanche with dash issues
tke395
