stuff for sell
greg_a_morton
blossom tx
Guys I have to sell some stuff to keep working on my mercury. All will include shipping unless stated otherwise. Since I need a few things for my truck I might trade for things I need. I need to buy a new gear reduction starter and a set of injectors. I need a transmission dip stick that will work with my ats kit for a c6. I may need a few other things that I will stat later. Here we go!
Core injectors 2 sets of BB and one set of B $15 for the Bs and $40 for the BBs
1994 factory ats turbo hat. $30 HAT IS SOLD
light Flywheel and adapter to mount e40d to idi. $100 flywheel is sold
good takeout e40d been sitting in shop a few years. suppose to be a 1997 model with all the good upgrades done to it. $400 pickup only
fuel filter housing with good paint and filter. $30 FILTER IS SOLD
two 6bt harmonic balancers different sizes. $50 for both
good looking egt gauge and probe wire. never worked in my truck but I think the probe was damaged when installed. $30
A very nice 5" rolled edge exhaust tip for 4" pipe. $35 SOLD
well this is my last item. This is a factory 4bt with th475 automatic transmission with a gear vendors overdrive. I had a fuel pin problem and that is the only problem with this setup. It needs something simple every one tells me but I have spent to much on this setup to go any further. I have over $7500 in this setup. The engine has about 70lbs oil pressure at startup and around 30lbs after warmed up. The engine is fairly stock except with the 35hp lennys fuel pin. It has a 5.9 manifold that has been cut down to make the turbo fit up high and work in a 67-79 ford truck. I will include all parts that I have extra cummins wise if someone does buy this. I will also include the $400 dollar heavy duty driveshaft that will work in one of these fords or long bed trucks. Any questions just ask and I will try to answer to the best I can. $4500
itsacrazyasian
residentcrazyasian
boca raton, fl
That banks turbo looks like its for an IDI? Do you have the up pipes for it?
What gear reduction starter do you need? One for a cummins for a ford idi?
edit i see you're trying to stuff a ford idi in there now. I have a "new" reman mitsubishi gear reduction starter at the shop. I bought it when i did my swap but my parts truck has a denso in it and it made it much easier to install.
greg_a_morton
blossom tx
itsacrazyasian it is for the idi. I have just whats in the pic. This was going to be used on a 67-72 ford truck and my friend bought off of the internet a few years ago. The price is about what I have seen some of these go for but my downpipe and pedestal is ceramic coated! If you have this kit and need extra parts or want to build the parts this would be a good starting point. I used the ats kit on my mercury and it fits my truck better than this kit because of the up pipes coming up the passenger side of the truck. If my 4bt sells I will keep this kit and will build custom pipes to work on a 6.9 in a ratrod.
wbw189
Metamora, Michigan
Thank you
Thank you, Greg.
Have fun on the Mercury! I love to see the unique trucks on this site.
Best wishes,
Ben
