straight water in cooling system?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
on my scout a sprung another leak in the rad, i patched it up, then refilled with water. i only plan on leaving it in maybe a month, or untill the trucks pulls and local shows are over. i don't want to spend the money on coolant because if it leaks out again i don't want to waste the money. will it hurt anything? :confused:
-Jon
Nope... Not a thing. Do run a flush before you refill with the coolant if you see any rusty water. Otherwise run it....
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I disabled the cap from building pressure too. It doesn't go above the normal temps with coolant and a good cap. I figured just thought id run it by you guys. Thanks! ;Sweet
-Jon
And you don't want to fix it because? :dunno You spent so much time and effort on that build, I'm confounded as to how you can tolerate anything less than perfection at this point.
dyoung14
Is getting worn out
spencer,tn
Im running straight water, but thats only because i cannot afford antifreeze
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Mel that's because I don't have $500 to have one made, and I don't have the money now to send it out to get repaired. Plus carlisle is in 2 weeks. Over the winter I'm gonna have that repaired along with a few other areas in need of attention. Plus I'm trying to get a 392 out of the machine shop for my '74 scout II.
-Jon
MR.T
PNW
This might be worth a look, Redline Water Wetter has corrosion inhibitors and some other additives for running without anti-freeze.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I think maybe for the time being ill throw a bottle of that in, $12 is a lot better than $72!
Thanks for the reminder.
-Jon
MR.T
PNW
I sure like that Scout of yours. That's a go-anywhere machine.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Thanks, she holds her own, need some lockers and it'll be pretty good. Its hard keeping up with my friends CJs, they fit through trees the full width axles get stuck between! Hahaha;p
-Jon
subway
be nice to the admin :D
York PA
used to run straight water on a regular basis when i couldent afford antifreeze but it rusted things fast and that can clog the rad and wear the pump. i imagine distilled water would be little better so it at least does not have the minerals in it.
water is actually a better conductor of heat than anti-freeze but it does have some major drawbacks in the winter.:D
dyoung14
Is getting worn out
spencer,tn
I will be able to afford it in the winter, but right now i cant
88beast
pa
scout you going to carslile? i may have to stop by and see your rig then
idiabuse
Princeton Fl
• Antifreeze/engine coolant is the most neglected fluid in the vehicle.
• Cooling system neglect is cited as the principal reason for premature engine and transmission failure.
• Cooling system failure is the most common cause of mechanical breakdown on the road.
• A national survey found that 7 out of 10 vehicles contain rust and scale and two-thirds of more than 8,000 cooling system repair jobs were performed on an emergency basis.
• Just 1/16th of an inch of mineral deposits on 1 inch of cast iron reduces heat dissipation by 40% and is the equivalent to 3-1/2 inches of cast iron.
• Over 60% of water pump failure can be attributed to seal failure.
• Over 50% of engine failures can be attributed to cooling system failure.
I just poured in 6 gallons of Evans Waterless Coolant in my new 7.3 that I waited 4 months till I could afford $300 for 8 gallons of the stuff.
I would never pour water in any cooling system I own, why pour corrosion, low boiling point, high pressure hose popping, water in a machine that I want to run perfect everyday without having to worry if my cooling system is pumping rust *****'ing up my whole engine?
Will it be ok? LOL!
smoking one ciggarette never killed anyone
Javier
