tbryga
what inch straight pipe would be the loudest on a 6.9
What kind of IDI, N/A or turbo? N/A I would think that the smaller the pipe, the more rasping and crackling it will have, where the bigger pipe will give it a deeper tone and give it less rasping.
I've got 4" on mine, and it rasps once I get above 2600 rpm's accelerating, or decelerating all the way down to 2500rpm's
no turbo.i found a hole in my pipe,so im just going to get a new pipe this week.what do you think a 5 inch or bigger would sound like
It would probably get rid of alot of the rasping that I hear in the vids that you post up. It will definatly be more mellow sounding down low, and up high it will be deeper, and up real high you will still get rasping. Seriously if you can fit 5" then I would do it, it would sound awsome.
You could have air in your clutch system. There is a clutch master cylinder on the firewall under the hood that is just to the passenger side of the brake master cylinder. Take the cap off, and see how much fluid you have. If you need to bleed it we'll instruct you how to do it then, because the way I did it it takes forever to write it up , and I really dont want to do that.
i checked the fluid and its full,i thought i might have air in the system but how could their be
Define loud....for more of a gasser snap you'll want a 2.5" or smaller. For a good deep sound go for 4"-5" exhaust. They sound too much like a gasser with anything 3.5" & under. Dual 5" stacks sound more like a Diesel!
well i have a 3.5 inch on it now.i want it to be as loud as i can get it
thats how my F-150 is...300 I6 with long tube headers, straight pipe and a tip...loud as ****.
any sound clips of ur set up cat rebel?
